Oil Types.
Originally Posted by Danno
^ Ive heard a lot of problems with the fram filters, I used one before and it seemed okay although im not sure it was doing its job properly.
mobil 1 10w-30 and mobil 1 filter, i got fram and valvoline synthetic this time cause they were out of what i wanted and i didnt want to go driving around. I figure i dont drive that hard and using the synthetic i wait till about 5000.
fram just seems like an american kind of filter to me for like mustangs and big trucks
a lot of diesel owners do not use fram oil filters because they can not hold the PSI that their engine needs. Leaks are pretty common too, the gasket could be better. I did an oil change on this guys 2.4 ralliart and their was oil shot behind the oil filter but the filter was tight. Had about 33k mi on the car.
I use royal purple 5 30 and napa gold oil filter every 3k.
also I do my own oil changes and switch out the plug and gasket every so often.
OK,
For those of you who are actually turbo. Have you guys tried running Synthetic Oil in your cars? Have you noticed and wierd side effects? I know RRM doesn't recommend it, but, for someone who's been running synthetic oil for some time now and then going turbo, will there be any significant affect to the car's engine?
Originally Posted by jchangsta2six
i just switched over to regular Castrol GTX 10W-30 ... before that ... i used quakerstate 10W-30 ... i still use fram oil filter tho ... and i hear the fram filter arnt as good ...
I use walmart synthetic oil...$12 for 5 quarts and I use their $2 oil filter as well...change it every $5K miles and have been doing so since 40K miles (when i got the car)
Car has around 107K miles on it...still going strong.
how could i classify on which oil to use? i use castrol gtx 10w-30 in the summer and 5w-30 in cold days. i am on my 30k in the next month. should i still use the same viscosities during this days? and when do you usually use those others such as castrol high milage, etc? or is it fine using the same castrol GTX on the whole lifetime of my car...
thanks mrshl
thanks mrshl
10w30 or 40 . . . Valvoline or Mobil 1 for my current car.
When I had my Mitsu, I ran 1 qt 0w40 Mobil + about 3 qts of 10w40 to thicken it up a bit. Otherwise, sythblend will do. I even tried an entire oil span using using 0w40 . . .
I use whatever filter . . . I used to stay away from fram, but I got tired of driving around town finding puralator. I don't know how of you can get 6-15 bucks oil filter and toss them away with ease with each change.
royal purple
i have 4500 miles and want to change all the fluids to royal purple
do you think it is to early and when i do i was going to use the k&n filters
i found some for 9bucks
ES stick 05
let me no
ES stick 05
let me no
