What could cause this other than alignment?
Sounds like this alignment didn't do much to prevent anything. I had this exact problem on my crap 711's in the rear. It was obvious when on the flat surface inside Discount Tire that the wheel was off camber-too much negative. I adjusted the camber correction on the control arm and it seems to sit flush on the ground now-fingers crossed.
This tire is pretty shot on the other side too. If it was mine I would leave it alone. The tires needed replacing anyways. Had they not worn abnormally you would have been driving on slicks in 5,000 miles anyways.
Thats what we call a broken cord... Usually due to aggresive driving and bottoming out the suspension, curb hopping or hitting potholes too fast... Sometimes its a manufacturers defect... They look to be out of balance as well, with the high and low spots...
Did he ever get this figured out? I was working on the car and I noticed my front passenger tire was low on tread. but the other three are still pretty full! i don't understand what the issue is.
did you ever get your wheels + tires balanced? unbalanced tires can cause wear patterns like that as well as the sounds you hear.
If you hear the sounds at higher speeds (eg. highway speeds) it's the balancing..
if you hear the sounds at lower speeds (city driving) it might be your air pressures.
naveed80
Dec 8, 2012 02:42 PM
Brewster
Oct 22, 2008 11:41 AM
sykou
Nov 8, 2005 10:14 PM
