Over Spray =(
Over Spray =(
Hey guys I need some advice on this I had some stuff painted on my car and i have some over spray on my front bumper. Is there anyway i can remove over spray? If i can what products to use and what procedures do i use? thanks again
Will WD40 strip the paint???? I do not want my paint being stripped just want the overspray taken off and i should add its a fiberglassed front bumper if that helps any?
WD-40 most likely wont work if its been there too long. and no, it wont strip the paint. you could use Goof Off, that will probably work. just make sure you wash the car shortly after. if that wont work youll have to use a clay bar.
Yea im trying to avoid repainting my numper It need it already but i bought some automovtive paint colormatched to my car in a spray can. Im gonna touch up my bumper in some areas its just to save some money. But I was told to try some rubbing coumpound?
+++1= clay bar
"Clay Bars were invented in Japan in the late 1980s to remove overspray and minor flaws from freshly painted vehicles at body shops. The preferred (and only) method of dealing with surface imperfections in the states was compounding, which does remove tiny layers of clear coat every time you do it."
I use this stuff from Turtle Wax for removing tree sap, tar, insects, and other crap. I used it on some overspray I had on some black plastic pieces and it worked great! Plus, it's only like $2 or 3...
