Evo VII weight reduction?
From what I understand the Evo VII has the most weight of the Evo series. Everyone pretty much says that since the Evo VII is a 2.0 engine that performance has suffered with the increase in weight. Is there any products that reduces weight? I want an Evo that has a enough comfort for daily use. How light could you get the Evo VII with all the products and certain ways to make the Evo lighter? Also, is all the weight reduction worth it in the end?
Actually, I think you have it backwards. I think the Evo VII is the lightest of all the Evo series, having a majority aluminum parts, along with all the hollowed out magnesium parts in the engine. Even the glass is 10% thinner to reduce weight!
This car is suppose to be slightly under 3000lbs, which is really damn light for a car like that.
Fron what I've read the reasons for the increased pork is due to the fact that the 7 is larger than it's predecessors but, they've also increased the "stiffness" of the chassis. Nothing like getting larger and stiffer at the same time
You can always go with lighter rims and remove unnecessary stuff from the interior if that suits you.
Mike L.
Mike L.
get a lighter flywheel, 1 kg saving will feel like 30.
You can also get carbon fibre hood/doors/trunk/spoilers but this is very expensive.
Saving weight is always good, better acceleration, mileage, grip, braking, etc.
Fireball, hate to say it but if you go to supercars.net. Look through all the Evolution and you will see the Evo VII is the heaviest out of the series. I realize that for a sedan that the Evo is extremely light, although it would have been nice to have it at least the same weight as the Evo VI. CuGSX, thanks for the info but I already knew why it was heavier. What unnecessary interior items are you talking about? 3171, wouldn't reducing weight with carbon fiber also reduce how safe the car is because the material isn't as strong? Do you know a site with carbon fiber products for the Evo VII? I still want to know if having weight reduction done would be worth it?
The evo vii is the heaviest evo, and the weights also depends if it is an rs or gsr.
You can get carbon parts for the evo as hood and trunk from monster sports in japan, and other stuff from rally tech in uk.
Dark Evo,
Maxi is correct, Monster Sport has nice stuff but pricey. If you are worried about safety you should not think about making your car lighter.
I think you can also take out some of the sound deadening material (which also means that you won't need any ICE because you won't be able to hear it anyway), take out the power windows (if you have a GSR), don't fill the washer wiper container, go on a diet, etc.
Anyone try taking out the rear windows of an Evo and putting in lexan windows? How often would you roll down the rear windows anyways?
Don't forget about taking out the spare tire and toss the a/c if you have a gsr.
Lets put this into perspective. The difference between a 6 and 7 is 40 kgs. So, if you are 2 up in a 6 and meet somebody on their own in a 7, he not only has the lighter car but he has a slightly more powerful engine.
Any differences due to weight are not possible to feel. The savings you would make on using Monster kit, or any other light weight panels, would barely be noticed on a road car. For the same money, buy engine tuning and gain more BHP. You will notice that.
For instance, if you saved 20kgs, which would cost you many $1000's in carbon panels etc your bhp per tonne would increase by 3 bhp! For the same money I would suspect you could easily gain 30 bhp by tuning which would improve the bhp per tonne by 21.5 bhp! I wonder which I would rather do.
Snelson
Trade youre car for an evo 7RS
Evo7 RS weight 1320 thats 40 lighter than evo 6 GSR and 80 lighter than evo 7 GSR
evo7 RS is heavier than evo 6 RS i know
But if you wanna go the route to lighten the car start off by buying an RS
Regards
Andre
Regards
Andre
Guest
Posts: n/a
To answer some of the initial question:
Carbon fiber hood and trunk: -14kg
Light wheels, depending on wheels: -10 kg
Air conditioning: 20 kg
AYC: maybe 30 -40kg
Light flywheel: -1kg but it will feel like you took of 100kg in 1st gear, 60 in 2nd, 40 in 3rd etc.
AYC: maybe 30 -40kg
Andre
I am very happy with a GSR as I use it every day and do a fairly high milage. I was just saying that removing weight from the body isn't worth the money. If you want to do it, you are right that you should buy a RS.
The 2 areas that I believe it is worth spending money on weight reduction, wheels and the flywheel. reduction of unsprung weight is very noticable and as Claudius says, you can easily save over 10kgs. In fact, on my car I am saving about 16kgs. Unfortunately this comes at a price - the wheels cost £3000 but they also look fantastic
The flywheel advantage has already been outlined and I totally agree with it.
Claudius
I am suprised you think that removing the AYC would save that much. Because you have to replace it with a LSD, surely all you really save is the pump and a few pieces of metal? I would be interested in your views.
Claudius
