FAST Key "Key" Not Starting '09 Lancer GTS
I guess I could have flipped through the manual looking for it, but I thought, with all these Mitsubishi owners on here, I would be able to get my answer nice and quick. Took a bit longer than I thought it would.
To use the fast key with a dead battery you need to place the FAST key on the back of the emergency key in the ignition switch. Then turn the key and it will start. The immobilizer antenna will energize the FAST key to start the car. You can remove the FAST key fob portion after the car is started.
I believe this is in the owners manual.
lemon_head
Mar 30, 2019 09:24 PM
