turbo charging my lancer
hey guys im looking into turboing my lancer
its a 1.8ltr 4g93 engine wondring wat turbo i can run on it
also can u only run low boost like 5 or 7 psi on a stock engine and stock ecu or how much can i run on a stock ecu
That sounds like the same engine from the mirage. That means you should be able to run slightly more boost than lancers, so like 10-12. Also you can use any 4g93/4 turbo kit you can find. You'd want a smaller T25/T28/16g (T3/T4 at most) that way it spools up fast and puts out a decent amount of power on stock internals.
I would suggest checking out the mirage forum (I think it's mirageforum.com but I'm not 100% sure) for specifics on how much boost you can run as well as what kits are out there for your car. You should be fine with the stock ECU as long as you don't go crazy. A piggyback ECU or a reflash is a must though.
ok then so yas think i can run a T25/T28/16g (T3/T4 at most) turbo on a stock ECU using a piggyback ECU or reflash just wondring coz ive been looking around n im thinking of getting a T3/T4
If you get a T3/T4 and run it on stock internals, you won't be getting the most out of it. I'd say for stock internals, stick with a T25/T28/16g for the best results. Then if you have the money to do the internals, you'll probably have the money to upgrade to a T3/T4. Those smaller turbos you can also run on the stock ECU if you get a bigger fuel pump and wideband o2 just to make sure you're running fine.
Yes, people are running between 5-7psi on any of those turbos with no tune. Just a bigger fuel pump (walbro 255) and maybe a FMU...12:1 I think. Any more boost than that and your will need bigger injectors and a tune for the bigger injectors.
thanks im just trying to get it all rite b4 i go n spend afew grand on this dont want to get it all wrong n stuff up n have to then try n sell it to get the rite stuff or have my engine go bang or not run at all
Check out the forced induction section of the lancer area. There's some very helpful sticky threads there. If you read those, you will have a much better understanding of the whole system
