Speedometer Problem
Speedometer Problem
I just installed the reverse indiglo gauges last week
. I just noticed last night that when I'm driving and I reach around 55 to 60 mph the speedometer gets stuck
and very very slooowly moves up then when I slow down it doesn't move
then it drops down to like 40 and decreases normal. What's the problem? Why is the needle getting stuck?
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
![Help Me](https://www.evolutionm.net/forums/images/smilies/help.gif)
I had the same problem with mine. I had to trim the inner circle a little. If you trim it use a sharp exacto blade and take your time. Mine only needed a hair of trim. I would check the tabs before you start cutting.
my speedo gets stuck at 38mph and 45mph and sometimes doesn't move and than drops drastically also..
i have the stock gauges and backgroud etc...i dont even have the black 'cover' on the base of the needle cuz i thought that might of been it...im gonna get the white face gauges to...just need to fix my RPM light...its burnt out.
There are at least two tabs to each guage but it depends on which ones you bought. You don't need to trim the tabs, you might have to trim the inner circle thats cut out to go over the stock guages. The needles are very sensative. If they touch the guages even just a little bit it will affect them.
Yes, but just the inner circle and just a little at a time until it doesn't touch the needle anymore and the needle moves freely. After you trim the inner circle a little, very gently move the speedo dial to 160 and let it go. It should slowly and evenly go back to zero without any hesitation if it is no longer touching.
CGroovy2k2
28
Nov 26, 2008 07:28 PM
