How to add underbody lights and interior lights
#34
Do you guys have any pics of your s*hit? I am dying to see the picture of your custom box with the neon on, sounds sweet. How about those bright blue lights?
#39
Location: Danville, CA (it really is all about nor cal)
i actually didnt run power all the way to the battery when i did mine. i tapped into the cig lighter behind the dash and just put a switch in off of that power. its clean (no visible wires) stealth, and any time my ignition is off, my neon is off, to save me from running it durring the day and axidently leavign it on after i get out and running the battery down......to turn in on when parked, all i have to do is be like im turning on the radio. it works out really really nice
#40
Thats a good idea. The cig lighter already has a fuse where it all ties in to the fuse panel, plus you won't have to worry about draining the battery. Not that neons take much power anyways. I accidently left my switch on overnight and I woke up in the morning worried my battery was dead. It wasn't . Kinda scurrrred me.
#42
I'd like to put blue neon lights inside my car, as well as my engine bay and trunk and just wire it into my headlight switch. My radar detector is already plugged into my cigerette lighter.
#44
Im wiring up mine with the use of the underdash light kit. Its a plug in play harness... im just gonna tap into it install some led's. This way they turn on when the door opens and fade away when they shut off. i will post pics and stuff when im done.
#45
1 Post
i need to get a pic but what i did was get a set of 4 led tubes and controler off ebay for $25. hook up a switch or run it into use fuse panel or cd player power and ground wires and you're set
