ground kit
there are no cons to a grounding kit. one that i would see is paying too much. just get some wires and ground everything that is previously grounded through your stock harness. you cant go wrong. ebay is fine. they do have voltage stabalizers which are suppost to.. well do what they say.
Since i have already replied to another one of your post and see this is the second post which requires a search behind it. i would recomend using the search then come with more questions after that has turned nothing up.
Good luck and welcome
better to buy ground wire and make your own. u might be paying less or close to the ebay ones but makes a good experience. only good thing is that it stabilizes voltage. and easier starting
i did mine and installed it my self.
i did connections as follows.
RH ground headlight to alternator to neg batt
intake manifold to neg batt
lh headlight ground to neg batt
tps to neg bat
valve cover to neg batt
tps to neg bat
no it's not. i'm going to DIY, as soon as I find a guide with the measurements of the wires. Not daisy chained either. I also want the gold plate that says ralliart that you stick on the negative terminal.
Here check out this
https://www.evolutionm.net/forums/sh...d.php?t=256473
