Stainless Steel Clutchline
Pic from the front of the car looking back towards the rear driver side corner of the engine bay. The clutch line goes behind the strut mount tower to the slave cylinder which is a REAL PITA to get at.
This is a view from that rear corner looking forward. The clutch line attaches to the hard-line on the transmission.
I had these pics since I did the install, so they aren't super detailed... if you need any more to clear anything up, I can try to get you some better ones.. just let me know.
Not a very hard mod. I did mine in less than 2 hours with bleeding the line and everything. I don't have lots of experience either. I followed very detailed instructions online:
www.evomoto.com
select the "evo tech" link
click on installations
click on driveline
click on braided clutch line/restrictor pill removal
Very easy to follow instructions. Easy mod to do as well. Have fun!!
www.evomoto.com
click on driveline
From: City O Sin, MA...the not so sinish part though...
word to the wise if your gonna do this yourself...install the line with the end of the line for the master cylinder side pointing up(with the line going down behind the strut tower). If you try to do it the way its supposed to be routed normally you'll have a BIACH of a time getting it threaded into the master cylinder. Once its threaded then bend it down the right way and tighten it.
Hey guys i have an automatic lancer es that i wanna switch to a manual transmission can anyone tell me what parts that i would need else i need? i have an idea but what we call it here in the cayman islands i belive you guys call it something different but here is what i know.
1. transmission
2. transmission console
3. shifter and shift knob
eddie
1. transmission
eddie
Thanks!
Thanks a ton for the pics and also for the link to the install guide. So does this make a difference with the "squishiness" of the clutch pedal at all? I guess I'll find out for myself soon though.
Thanks again,
Mat
Thanks again,
Mat
