OEM Fog Lights
OEM Fog Lights
Hey guys,
I have an ES and I'm thinking of getting the OEM Fog Light kit on eBay and doing the install.
I was wondering if any of you have done this. (which I guess would be pretty few if any considering that if you wanted them you would have bought them, I just didn't know how much I would want them after deciding against it)
If by random you have I would really appreciate some input.
Thanks!
Thanks!
Well I already posted some information here:
https://www.evolutionm.net/forums/sh...d.php?t=286759
The kit comes with the instructions on how to do everything except the bumper removal. But for all extensive purposes you don't really need to remove the front bumper. There are enough openings to squeeze your arm through the engine compartment as long as you remove the air intake and the plastic cover where the Hood release is located.
There are clips that hold the wire harness in place and just snap into pre-drilled holes. Its pretty easy just beware that the feature will have to be initialized in the ECU by a mechanic.
Kevvsworld
Jul 9, 2021 09:29 PM
kamillionaire5
Mar 25, 2009 11:47 PM
. M i c h a e l
Jul 18, 2006 11:29 AM
