Trunk Carpet Problems
WORKED! all I had to do was hand stich it to the carpet then I put a new piece ontop of the old piece. I was a pian to sew it by hand buy I had to do it becasue the sewing machine that my friend had, got all sticky from the glue on the bottom of the velcro so it did not work, best to do it by hand!
No I just have the basic 6 speaker 160watt I think?? Sound system. I am adding 2 12's with a 750 watt mono amp mounted to the back of the seat. Check out my cardomain for pics of the subs and box, I dont have the amp yet, I have to save up 600 dollers to get it put in, bought the box with subs from my cusin for 150.. I think its a good price what do you think??
Im not sure. I only know the basics when it comes to audio. I do know that $600 sounds pretty high just for a 750 amp installed. How much is the amp? You should buy the amp and put it in yourself. With a little research, I think you would be able to do it.
and if your truley into autoX.. then you know that a FWD is typically *** light, and having a sub set in the back will more then likely equal out the weight distribution .... but that's just kid stuff right?
Chickenmcjames
Jun 8, 2013 03:19 PM
J Money
12
Dec 9, 2007 10:46 AM
NWEvoViii
17
May 21, 2007 04:40 AM
