View Poll Results: Which is best for my cause?
Voters: 45. You may not vote on this poll
SOHC Civic vs. Lancer OZ vs. Lancer
#31
Looking for a sporty car for around $8k that you can mod and has good hp stock? If you like the Mitsu family, go for the late 90's model Eclipse. GS-T or GS-X are both turbo. GS-X is also all wheel drive. I think the stock hp is around 200-220. If I had it to do over again I would've found a GS-X and passed on the OZ Rally.
#32
I wanted to include a pic just to be clear which body style I was talking about. Unending mods available and starting off with a great stock product. They can be hard to find but ebay almost always has a couple listed.
#34
What are some common problems to look for when buying one? Either a GS-T or a GS-X?
#35
Only common problem I've heard about is crank walk. Check out some eclipse forums or just search google to find out more about it. From what I remember the problem was with the original factory installed part (bearing I think), basically like a bad lot of that part or something. But once it's fixed it's good to go. Not cheap, but if you find one that's already had it done than you don't have to worry about it. Otherwise, if you find one that hasn't had the problem yet it may be in the clear. Most of these cars are already up in miles a little ways. I think most commonly this problem was hitting around 70k miles. Don't quote me on all of this, it's been more than a year since I researched this.
#36
Well i'm doing a swap.. so thru research i know a lil something about eclipses... CRANK WALK is the only issue... This only happens in the 2G eclipse.. Alot of eclipse guys swap the engine to a 1g or they just put a 1g Head on top of the 2g.... the engine that i bought happens to be a JDM 1g (thank god!!.. so we'll see what happens) But also if i could do it over again id find a GSX.... (screw the GST.. AWD is the way to go!)
#39
d series what go b series more potential for power and what do you mean vtech isnt mod friendly uh its pretty easy i had a b16b in a 89 crx and i had it fully stripped weighing in at 1400lbs redline was 13k and could knock the wind out of pretty much any thing stock turbo. Honda motors are much more friendly to mods
#41
#43
#44
y would u spend 8k doing it?????????? maybe 1or1.5 k but not any were near 8k.......or maybe because i live in san antonio and theres a HUGE import sceen were u can get anything for REALLY cheap!!!
#45
I read your question and won't bother reading 3 pages worth of replies. Sorry if it's been posted already.
Kepp your Civic. And that comes from a guy who currently owns a Delsol and a Lancer. The Lancer looks better, I'll give you that, but it will never haul @ss like a Civic can. There are plenty of D series out there that push well over 200 whp on stock internals. According to people on here, you won't see that happen in a Lancer.
A Lancer needs load of cash to make it somewhat quick. That same amount of money would swap a Bsomething in your Civic and you'd still have money left for bolt ons.
