Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Botton near the pedals??
Old Oct 28, 2007, 08:08 PM
Noe18's Avatar
today i was installing my fog/driving lights and i saw a small black botton on the left side of the dead pedal im going to take some pictures tonight
Old Oct 28, 2007, 08:17 PM
atilla's Avatar
pretty sure that's just a grommet and not a button.
Old Oct 28, 2007, 08:34 PM
Noe18's Avatar
i dont think its a gromment, mayb its was nitrous botton LOL jk, does anyone has this??
Old Oct 28, 2007, 09:53 PM
Noe18's Avatar
any1
Old Oct 28, 2007, 09:55 PM
NOTORIOUSLANCER's Avatar
Did u press it to see what it would happen
Old Oct 28, 2007, 10:10 PM
CityKnight's Avatar
There is a button, I have it too.
I thought it was part of my after-market alarm system, actually.
Im surprised to see that someone else has it..???
I've pressed it on more than one occasion.
I havent noticed anything different about the car.
Old Oct 28, 2007, 10:11 PM
90GSX-03EVO's Avatar
Bought the car used?
(Car alarm reset switch.)
Old Oct 28, 2007, 10:13 PM
Noe18's Avatar
mine was used too, i never saw it till today and thats because i never had to look under there but i turn the car off and pressed results nothing then i turned the car on and still nothing, it has to be a reason
EVOx2008's Avatar
No instantaneous 5000HP? no traction at any speed? on ice? up cliffs? upside down?
Does racer X show up?
they should make a speed racer movie...
Old Oct 28, 2007, 10:16 PM
Noe18's Avatar
i have stock alarm and i thought it was for resettin the alarm but nothin, before i use to put the alarm on and i heard the horn and a beep sound now i only hear the horn also the alarm light stays on and only turns off when i start the car
Old Oct 28, 2007, 10:18 PM
Noe18's Avatar
LMAO thats funny, but when i pressed it and got out of my car the es transforme into a evo 9
Old Oct 28, 2007, 10:38 PM
eponti's Avatar
Reset button?
Old Oct 28, 2007, 11:37 PM
sykou's Avatar
Looks to be like the "momentary ON" buttons they install with aftermarket alarms. What it is used for is in the case that you lose your keys or alarm control you can open the door and press the button a pre-specified amount of times to unarm the alarm. The drivers lower kickboard is the most common place these buttons are installed in because it is relatively close in relation to the "Brain" of the alarm. The setting is pre programmed at the time of your alarm installation so if it is dealer installed you should be able to ask them what it is set to. And if i were you id rewire the button to hide it in an inconspicuous place where it is not easily found/reached. Good luck!
Old Oct 29, 2007, 12:26 AM
vial8or's Avatar
to the guy with the speed racer pic, they are making a speed racer movie
coming out next year
Old Oct 29, 2007, 12:56 AM
UT_Evo's Avatar
They are.
Quick Reply: Botton near the pedals??
