question..
question..
I'm bored and not doin much so i just started lookin around for things...im lookin on ebay at headlights and stuff and i see the HID plug n play bulbs er wutever..but i see em for like 12 buks and 9 bucks shipping...has anyone actualy ever used these or seen them used?
if so how are they? thesde ones say 8500k..is that really wut ur getting?
thanks
thanks
Don't use any of those higher-than-stock output bulbs unless you use any upgraded wiring harness. Those probably aren't HIDs seeing that the price is way too low and that there was mention of a ballast or anything.
i thought it runs at the same wattage er same output er w/e..yea im prly not gunna go with it only because its too cheap to be right..idk i was just curious...i want to buy new head and tailights anyway..any suggestions as to where? i want the black look and i dont think i trust myself to do the DIY blacking out with the oven and what not..i can just see myself effin up..
ohh little grasshopper, you must search more.......
look into cedia lamps if you want the best dark headlights
btw, plug and play bulbs are NOT hid's. HID's require a ballast. HID-like bulbs are only similar in color, not range or clarity.
