removing door panels
Just use a very small flat-head screwdriver for the handle-area screw, then all the others are easy to access. The panel will just pop off after the screws are removed...simple plastic plugs hold it on.
Come on man, look at the door! While the door is ajar, look for all the plastic caps surrounding the panel. Use a small flat-head screwdriver to pop them open, then a Philips to remove them. Using flat-head screwdriver, pop open the little square panel in the middle of the lock/unlock door handle area. Then there's one in the small door pocket handle thing at the bottom. Pop up the small square panel, the that should be the last screw. Then just pull on the door panel firmly, and the plastic plugs will pop out all around the door. DONE!
