Two pictures need advice
Is this a cause for concern at all?
My friend got his lancer a couple months ago and he did not have this sticker thing there. and there is rust where my sticker is on his car. Is this really a sticker? It seems since the winter there are tiny tiny white dots on that piece of whatever it is. How do I remove it.
Thanks.
I had the same thing untill I covered it with the GTS side sills You can still see them a bit but if you go and look at a GTS it also has the same sticker. I find it weird now that you mention it that your friend does not have that sticker.
If & when you decide to remove the 3M sticker, make sure it's warm - either a warm day, or take a blow dryer to the sticker - then slowly peel from one direction to another. You may also decide to use some floss to smoothly take it off. May or may not want to/need to use Goo-Gone afterwards, if the car surface is a little sticky.
mine started to peel off in about november. I went to the dealer to get it replaced and apparantly it is still on back order. I can't believe a small piece of sticky plastic can be on back order for 5 months haha
