Cluster
Cluster
I own an 02 lancer es and want to change up the interior a bit. The first thing I want to do is switch out my cluster for an OZ Rally gauge cluster but I'm not sure. I drive a manual.. my question is can I buy a cluster from an automatic oz rally and have it function the same in my manual transmission (ie. my car has no cruise control)
Thanks for the help. I tried a search but it didn't come up with anything addressing my question.
You can swap your cluster, but i would prefer you getting a manual cluster instead of a auto. You can try asking around. I'm pretty sure someone has cover this in the how to do section. i think thats it right there. https://www.evolutionm.net/forums/sh...ad.php?t=66953
i know how to remove and replace it (i've changed the gauge/dash lighting using lightrikz), but my question is can an automatic cluster work in a manual?
I don't see why not; the only difference i could foresee is the cruise control light since a manual obviously doesn't have this feature.
yeah i was about to say....manual lancers have cruise control...mine has it. And wouldn't a automatic cluster have like P,R,N,D,1,2,3 ?? I would think a automatic cluster would work....but i think i read somewhere that when someone did a tranny swap from a auto too a manual the speedometer wouldn't work.
The speedometer wouldn't work after he did his swap because an auto trans has an output shaft speed sensor and a manual trans has a vehicle speed sensor. He had to change the wiring to the sensors so that it was hooked up correctly. The signals coming into the cluster are the same for both auto and manual Lancers. Where each of the signals come from is the only difference.
The speedometer wouldn't work after he did his swap because an auto trans has an output shaft speed sensor and a manual trans has a vehicle speed sensor. He had to change the wiring to the sensors so that it was hooked up correctly. The signals coming into the cluster are the same for both auto and manual Lancer. Where each of the signals come from is the only difference.
i did the cluster swap on my 06 from an 04...but my question is that when i was taking my old cluster out i noticed that it had what looked to be a shift light...i wanted to know if anyone knows the wires to get that hooked up..
what kind/model of 06 lancer do you drive? i would say in some places our lancers are very differently made and come equipped with things the US market does not offer.
