Driver Door panel removal
Hi, anyone got info on how to remove the driver door panel? diagrams or pictures will help
I have a rattling noise coming from the door an I want to check it out.
haha ive done this so many times....
there are 3 screws to take out first. one is behind the handle that you pull to close the door from the inside of your car. remove the plastic piece and take the screw out. the next one is behind the other handle, that you pull to open the door from the inside. take off that little plastic piece and take the screw out. then go to the outside edge of the door panel and there is a little round plastic piece covering the last screw. take that screw out. now just pull the door panel off the door and you're good (its held on now only by plastic clips). i found its easiest to start pulling from the bottom.
good luck and sorry i have no pictures
