Valve set
Valve set
Has anyone had the luxury of checking or getting your valve set checked? I read it over and as a mechanic I know how to do it...but being the adjustment procedure I am wondering if anyone has had to have an adjustment.
To adjust these valves (if necessary, you are allowed +/- .0012") you need to remove the camshaft(s) and change the tappet height between the valve stem and the camshaft. They apparently come in .0006" increments.
I really hope my measurements are within spec in the next little while as I have to check it soon...
