Possible to fix CF Hood with Bondo or Fiberglass?
Hi I have this VIS CF Hood for my Lancer. The Corner is broken down to the mesh as seen in this picture. Is it possible to fix this with Bondo or Fiberglass and just paint it to match the rest of the hood.
![](http://i97.photobucket.com/albums/l231/Squid267/New%20for%20Lancer/DSCN3151JPG.jpg)
![](http://i97.photobucket.com/albums/l231/Squid267/New%20for%20Lancer/DSCN3147JPG.jpg)
yes you can. you cannot however rebuild that corner with bondo. You will need to use fiberglass to reshape the corner and then clean it up with bondo. Basically, do some googling on how to repair fiberglass and it is the exact same procedure. I worked with it on motorhomes for 2 years, its pretty simple stuff.
