How to do a Transmission Flush: help
if you want a true flush, you have to take it to mitsu. And if you are replacing CVT fluid it takes about 6L, but do check as filling, to make sure to not overfill. Also you need to check while the vehicle is running in "P" or "N". Mitsu recommends you do the fill/run procedure and drain a little each time until the fluid is clear, then top up to correct levels.
trinibt65
Aug 22, 2015 01:42 PM
09, 2008, 2009, ctv, cvt, drain, fill, flush, helps, lancer, location, mistubishi, mitsubishi, pan, transmision, transmission
