Lancer ecu to zeitronix Zt-2 wiring
Well guys I installed my zt-2 the other day after 2 days of researching wiring diagrams , everything is connected to the lancer ecu , this is for 02-03 lancers with auto trans and pre 2010 zt-2's I'll do the manual one in a day or so but I believe the pins are the same you can verify by ecu wire color in the meantime
zeitronix: ecu:
green--- pin#43 green/white
red--- pin#47 red/yellow
grey--- pin#78 green
brown #8--- pin#57 black
black--- pin#42 black
these are all you need to get going, check out the zeitronix site for boost sensor hookup /warning light hookup etc.
www.zeitronix.com
zeitronix: ecu:
www.zeitronix.com
So do you use the purple for simulated narrowband o2 output? I've always wondered if people remove the existing o2, and replace it with the wideband or if they weld a new bung and leave the stock o2 as is.
dr_latino999
Jan 3, 2014 03:15 AM
tboboy
Aug 7, 2010 03:39 PM
Extas
Apr 25, 2010 06:36 PM
TTP Engineering
EvoX 'For Sale' Interior Styling
18
Dec 1, 2009 12:45 PM
TTP Engineering
62
Apr 24, 2009 03:26 PM
