HOW TO: Fix Cruise Control On RRM Bored TB
Here's a video of how to fix your cruise after you've installed the RRM bored out throttle body.
Fix works great.
Drove over 1,500 miles using the cruise, no problems at all.
http://www.youtube.com/watch?v=RdFzu...el_video_title
Fix works great.
i cant even get my cruise to work,weird thing is on the vaccume pump on passenger fender it has a line ran to the intake manifold and the vaccume line on the fuel pressure regulator,that i thought was supposed to be hooked to the intake,is plugged off,,,,any ideas?
The small black vacuum pump on the passenger inside fender should have a wire harness powering it, a small elbow hose about 1" long connecting one part of the pump to the other and a small hose going back to the intake manifold.
This hose does not connect to the intake however, it connects to a metal line and goes over the intake manifold and then goes back to a rubber hose and connects to the cruise control piece on top of throttle body that is pictured in my video.
So in short; The small black vacuum pump on fender of passenger side only goes to the cruise control "dome" on top of TB, no where else.
I would hook all this up as I've said (once you get you new TB lil' jeff) and see if it works.
If it doesn't then it maybe that it was disconnected because the pump went bad.
the guy that had this car was an idiot,i came to the conclusion that,after just replacing the motor a couple weeks ago myself,that he had replaced the motor before and used a motor that wasnt set up for cruise and just started blocking off vacuum lines. im finding all his mistakes and fixing em. thanks
im tryin to find a way to fab mine up. my tb wasnt set up for cruise but the car was...go figure and the wrecking yards wont part out anything on the tb. all i need is the little bracket that catches the cruise lever!!!!!
Are you sure your's is long enough?
If so you could try a small L bracket or something like that.
it looks like the threaded rod that the lever is on is longer but right now i just need to make it work,i just bought the vacuum part on the throttle body but now im tryin to get it to work.
DontStopMe
Mar 18, 2017 12:36 PM
gridiron44
Jun 5, 2010 10:30 PM
atilla
Aug 25, 2006 03:01 PM
