Tweeter install??
Tweeter install??
Ive recently installed a set of pioneer component speakers, and I have yet to install the tweeters. If anyone has seen the factory tweeters located behind the a-pillars, the bracket or holddown is not really reusable. I cant seem to find a sutibale location for them, without looking too intrusive, or without hacking up something to custom fit them. Has anyone some pics or tips for install on some tweeters?? I'd appretiate any help..
I mounted the tweets in the stock location behind the a-pillars. I removed the stock tweeter bracket and used the same screw hole to mount the tweeter. My tweets came with a mounting cup. I just drilled a hole in the mounting cup and screwed into the hole that was used for the stock tweeter bracket. The tweets snaped right into the cup. The pillar panel went back on just fine.
It was tough getting the tweeter bracket screw in and out. I used a small right angel phillips driver.
I just took a look at the stock tweeter bracket and it looks like it would be tough to use with an aftermaket tweeter unless it fits in the black housing. Good luck man.
hotrod11686
10
Feb 29, 2012 07:11 AM
Noize
22
Apr 18, 2008 11:15 PM
Psythik
Jul 1, 2007 08:01 PM
bcustom152
13
Sep 17, 2002 07:26 AM
