Installing a new system
Mods: Please move this thread if necessary
Members: If this has been already discussed, forgive me - please provide links if possible.
So I just bought a JL audio bass system including subwoofer, amp, sub box, and amp wiring kit. and was wondering if any of you have installed an aftermarket sound system in your RA? I do not have an aftermarket HU and like to keep the stock HU if possible given my car only has 1K miles on it. I do not have the rockford fosgate package. What exactly do I need to do to get all of this installed?
Thanks.
Thanks.
It has been discussed, i'll try and find a link.
Bottom line though, for the BEST sound, GET A NEW HU. So much clearer sound. Otherwise you'll have to get a hi-lo converter which sucks. A lot.
Thanks.
Thanks.
I personally went all out with my system, new head unit, dual amps, new speakers, two subs. I could not be happier with it.
Okay, well all that is really needed is a line-out converter. Aftermarket head units have separate speaker and sub level outputs (typically), the line-out converter essentially adds that sort of functionality, but you won't have very good equalizing control over it (turn the bass up, it goes up on ALL channels, sorta bad for stock speakers due to poor frequency response).
Hmmm understood....I just hate ditching my brand new stock HU if nothing is really wrong with it "dont fix it if it aint broke" type of deal going on. But Just curious how much did you dish out for the HU dash kit and was it hard to install? Also for those who cut out their speaker wires or got the converter, where did you hook up the amp remote wire? (the signal wire that turns the amp on/off).
i kept my stock hu and just added the loc-80 to convert the rear speaker outputs to the lower amp frequency required. tapped into the wiring behind the headunit coming off the harness for the 4 speaker wires (LR +/-, RR +/-). the sound was alright. way better than nothing at all, obviously, but i had to dial up the amp settings to get the sound i wanted without pushing the stock speakers too hard. remote wire i ran completely separate, used a fuse-tap in the fuse box on the radio power fuse and ran the wire back from there along with the main amp power wire.
That's what I just bought, do u think I could tap the rear speaker wires at the trunk instead of the rear of the HU? I don't really want to dissassemble the dash if i don't have to I know noise maybe a problem. Also where do u get fuse taps at? Do u remember what fuse is the radio fuse?
dont worry about taking apart the dash, its very simple. if you want, i'll do a step by step, but its definitely not a huge deal at all. just a few phillips head screws and some clips holding everything in.
for the fuse tap, i just went to auto zone. it looks like a little black box where you can plug in 2 fuses on top but it only has one set of fuse prongs coming out the other side. and its got a red wire running out of it to connect to the second circuit as the power supply.
as far as which fuse, if you pull the cover off, look for a picture of a music note on the back of it, and then match the position of that with the alignment location of all the fuses in the block and there you go.
the problem is, they're not in the trunk, they're in the doors, so you'd have to pull up both sides of the rear floor trim and the b-pillars to get to the harnesses that the speakers run on and then splice into each side and run separate wires from each side back into the trunk and then hook them into the loc. i thought about doing it that way too, but it was way too much. i just tapped into the radio with the loc and ran a regular set of rca wires all the way back from behind the hu.
A how to would be very very helpful
just do not forget to add some pics, I just do not want to mess up my brand new bebe
Ok everybody I am actually getting ready to install this. Can someone provide any tips on how to route the power cable?
Did you drill the firewall or is there any convenient way into the cabin? What parts did you take off etc? Thank you!
cyniclaus
Mar 2, 2009 08:34 PM
davidvscali
Sep 6, 2006 09:52 PM
KrnKid
Nov 13, 2002 09:37 AM
