drilling carbon fiber hood for pins
#31
i might be able to snap some pictures tomorrow. i used the pre-drilled holes near the headlights. on the driver's side i had to move the secondary latch release and zip-tie it to the frame just behind its original position seeing as how there's a plastic clip holding it in place in the pre-drilled hole on that side. i drilled them out just a little bigger and then tapped them for the sparco posts.
#32
the new pictures with better lighting do make it look a little better.
and yeah. I sold Atilla the wing. Which I bought from RRM. I am not sure if they have any left or not.
Im also interested to see where you mounted the posts just encase i do decide to add pins ever...
EvoIXMR
Jan 7, 2006 04:22 AM
