ferrari shift boot, help
Old Mar 7, 2008 | 10:46 PM
TheShortBus's Avatar
i wana see how this comes out!
thats one of my favorite things about Ferrari's interior.
im guessing your goin to have the outer edge of it as a circle right?
Old Mar 7, 2008 | 11:05 PM
M@verik's Avatar
I actually tried that. Its very difficult to do, but it can be done. Just the problem is u can see all the internals through it and it looks crap unlike a ferrari or lamborghini one
Old Mar 8, 2008 | 11:34 AM
ambystom01's Avatar
Originally Posted by 4WS@TopLevelAuto
theres alot more play in our cars than Ferrari's have... Their shift is stiff and direct, its pretty hard to miss gears, it just slides right in perfect so they can get away with the plate... If you do decied to do it i would make the gapping as large as possible or maybe just make a shorter boot like how bmw makes their auto boots. there maybe 2 inchs of leather versus 10-12...
Cheers!
Agree with this. The plate will look very weird if each lane is gigantic as would be necessary to take into account the play in the shifter.
Old Mar 9, 2008 | 06:25 AM
OZ_kidd's Avatar
CoastieOZ I cant find the pic. i been looking all over.
I might suggest also trying plexi glass instead of aluminum.
I know this is not the exact pic, BUT its the idea. this is civic DIY shifter console.
pics for progress!!!please.
Old Mar 9, 2008 | 06:27 AM
thejeebus2002's Avatar
I'd have to agree with the fact that it probably isn't a good idea to limit the travel of the shifter with these cars. I imagine the Ferraris are very specific in terms of gear selection. I'd just get a better looking boot (I agree with you...they look like crapola).
Old Mar 9, 2008 | 06:32 AM
OZ_kidd's Avatar
I know a lot people here are not supporting you for this idea. I say JUST DO IT!! If it doesnt work THEN oh well.
Prolly have to do a lot of test fitment and clearance checks. Better have a DREMEL.
Old Mar 9, 2008 | 12:39 PM
Blacksheepdj's Avatar
My personal favorite - rally style. Remove the entire center console. I had my Lancer like that for a while (rear seats were out too). The only problem is if you're used to leaning on the console when you get in (I am). You tend to fall on the floor a lot.
Old Mar 9, 2008 | 12:49 PM
purevibez's Avatar
hahahaahaha. i lean on my center arm rest alot too. do it dude. it would be fun to see it. good luck
Old Mar 10, 2008 | 03:11 PM
CoastieOZ's Avatar
is that a piece of rubber? or hard plastic?
any links to that diy, might help.
trying to get the lanes right and even though i have a short shifter it still isnt that precise, and that hole is small, also ive pulled the little silver ring off in this project (accident) oh well i guess superglue?
any other shifter idea's ?
Old Mar 10, 2008 | 03:14 PM
CoastieOZ's Avatar
nm, found it
http://www.honda-tech.com/zerothread/1303448
anyone like this look, might try to modify one like this but maybe stainless or cf?
Old Mar 10, 2008 | 04:48 PM
apexlancer02's Avatar
are you using a short throw while doin this?
Old Mar 10, 2008 | 05:35 PM
CoastieOZ's Avatar
yes i am, this is temporary solution, ugly boot
Old Mar 12, 2008 | 01:55 PM
CoastieOZ's Avatar
okay update here, i got all the measurements for the shift cover and im going to try and cut one like the pic of the one above on the honda and probably cover it in carbon fiber or black vinyl
unless anyone can think of an alternative?
Old Mar 12, 2008 | 02:06 PM
Tristar's Avatar
The reason Ferraris have that type of plate is because its a gated shifter, it requires precise movement, and to go from 1st to second you actually have to slide the shifter over into nuetral before moving down to 2nd.
That being said, I dont think your idea will work. I could be wrong though. Either way, that type of shift plate will force your shift throws to be more up and down, rather than direct on angles (like 2nd to 3rd), making them slower.
Old Mar 13, 2008 | 05:50 AM
CoastieOZ's Avatar
yeah thats the problem it looks like a big six point star kinda thing, so im gonna try the cover thing like the one above, will update with pics soon.
Quick Reply: ferrari shift boot, help
