novice please help
Old Aug 29, 2003 | 06:00 AM
pasang_8848's Avatar
novice please help
Hello all,
I recently bought a Lancer OZ 2003. I don't like the wheels it came with and want to replace them with 17 or 18 in wheels. Do you have any recommendations on what wheels should I go for? I don't have a lot of money to spend.
This is basically a commuter car for me. I don't do any high speed driving or racing etc. I just want the car to look a little better. I am also wondering about the long term dammage if any of the bigger wheels. Thanks a lot.
PL
Old Aug 29, 2003 | 06:18 AM
Neal@tirerack's Avatar
The easiest thing to do is visit us at www.tirerack.com and check out our Upgrade Garage. You can see your car with the wheels on it as well as the individual prices. Check it out at the following link:
The Tire Rack
Let me know if there is something you like
Old Aug 29, 2003 | 07:58 AM
Thanks Neal!
I would like to know about the long term damages to your car if you use the custom wheels. Manufacturers prefer you stay with the same wheels size as the stock wheels, isn't it? What does the Mitsu say about lancer OZ 2003. Thanks.
Old Aug 29, 2003 | 09:30 AM
Using the correct size wheels and tires should not cause any vehicle damage. Because a lot of cars today have systems such as ABS, traction control, AWD, etc that work off of tire diameters, manufactures recommend staying with a tire that is the same diameter to avoid problems. All the plus sized tires and wheels we have will stay within the manufactures recommended specs.
Old Sep 10, 2003 | 03:58 PM
LBLancerDude's Avatar
what kinda bolt patern for the OZ?
Old Sep 10, 2003 | 05:04 PM
TURBOit's Avatar
i like www.tires.com, they too have a place where you can view many rims on your car, personally id go with 17" rims, 18s are nice but tend to look too big on the lancer and have less than an inch of rubber between your rim and the ground, also with the 17s go with a 215/40-17 tire, most of these sites you dont need to know bolt pattern, its in the owners manual, i dont remember off hand, but you cant go wrong with upgraded rims and tires
Old Sep 10, 2003 | 07:50 PM
03RallyLancer's Avatar
114.3 or something close to that
Old Sep 11, 2003 | 08:16 AM
Wheel specs for the 02 Lancer OZ are 4-114 bolt pattern, 67mm center bore, 40mm offset, and wheel is 15X5.5
Old Sep 11, 2003 | 09:35 AM
i_love_spool's Avatar
ES has a 4X100 bolt pattern
LS, OZ have a 4X114.3 bolt pattern
Old Sep 11, 2003 | 09:51 AM
Roger that... thanks!
