Port & Painted Intake Manifold
I had a little project I was doing the whole week. It only took so long because I painted it 2 coats everyday so I won't have problems with paint later.
First, I cleaned it with TB and IM cleaner. That stuff really smells
Second, I gasket matched the runners with permanent marker.
Third, I started porting.
I notice pretty good gains from this, especially the low end torque.
Installation was cake, just make sure you label what goes where.
I have the stock Intake Manifold for sale...
https://www.evolutionm.net/forums/sh...d.php?t=383315
I can give it to you stock or Port & Painted.
Well there is no need to polish the manifold.
Port & Polish is more for the Cylinder Head and Exhaust Manifold.
Hey you're local, if you want I can help you do this fun project.
1 Post
Well there is a difference when you polish the manifold. The point is to reduce the turbulence of air as much as possible. A bunch or rough spots will decrease how fast the air can get to the motor.
