i need help painting my evo wing!!!!
i just bought an evo wing from plasticpyro and the bridge is already painted. i need help sanding and painting the middle part in. i have a silver lancer. so how should i go about painting this and get a good color match. im planning to sand and paint it my self. maybe stop by at pepboys and buy a couple of can of primer and paint. but i dont know what shade of silver to pick up.does anyone know where i can get the silver shade i have or all silver are the same? and what kind of sand paper to use? and when i do sand it. is there any particular way in doing it? so that ill look smooth. finally. how can i keep the carbon firber black and shiny? the sides are carbon fiber and the bridge is fiberglass.
use wet sand then prime. after dry (thouroghly) wet sand again with even finer paper, prime again then paint with color. (get it in a rattle can from paintscratch.com it will be the EXACT color) clear coat to finish it off..... the key is patients, let coats fully dry before sanding or painting another coat.
also the wing i got from plasticpyro was the side cf and the bridge fiberglass. im not sure the cf side would look nice. color doesnt seems to match. so should i paint the carbon fiber also. so the whole wing would look silver.
Search around the web for a couple how-tos on painting. It will come in handy - everyone's got different methods and it can be difficult finding patience. You're going to sand a lot more than you expect. Sand it first (maybe 800grit wet sand), then primer and wet sand that with something finer, maybe 1200grit or more. Next paint that with several coats (5 or 6) and make sure to let it dry very well after each. This is best to do in a ventilated part of your house by the way. I'd say wet sand it once more with some super fine grit (like 2000) and really work at this sanding. It won't be perfect, but it should be close when done. Put on more coats. Use some rubbing compound for a final sanding which should make it shiny and glossy and smooth if you work hard enough at it... Then the most important part...
If you haven't gotten a shine like you want to (I never do, though its theoretically possible with just sanding), get Meguiar's Scratch Remover. Use it. Then follow that up with a polish and wax and you'll be all set.
-N
-N
emperor_gp
Sep 20, 2005 03:14 PM
EVO MR FU
35
Nov 8, 2004 07:52 PM
