View Poll Results: Which style Carbon Fiber Hood should I go with?
Voters: 30. You may not vote on this poll
Juan Martinez Customs End All Build Thread
I figured it was time to start my build thread. I see everyone else with theirs and I feel left out. I have both an 03 Oz and an 04 ES. This thread will mostly focus on the 03.
Here we go.
The way she looked right after we got it.
She came with a different set of aftermarket taillights I didn't like, so I went evo style right after we got it
My cd player and in dash monitor, the monitor is gone now, and will be replaced with something else. The Sony cd player is about to go also.
I threw in my Kicker L7 and kicker 1000.1 amp that I've had since 2005. It has really held up to the abuse. The amp is probably a 2003 or 2004 model which I got used.
Here is my kicker component speakers.
Here is my cold air intake. There is also a ss clutch line install on there now.
These pics are from the fall and need to be updated. I also plan for my next update to show my plans.
Here we go.
Ok, here is the first wave of plans I have when tax time comes.
First. Pioneer DEH-P9800BT
Pioneer UB-100. I prefer to use my HDD and have all my music with me.
Plan on buying these also and using a 6000k HID kit
Here's what is replacing that indash monitor
And because it looks naked without gauges
The big plans down the road
Complete 5 lug, rear disk, and brembo brake conversion. I have figured out the rear, just need to figure out the front.
I am now taking suggestions on 5 lug rims 17x7.5 or maybe 17x8 with an offset (38+) that will fit over evo brembo calipers
I'm buying all the pieces seperately. I believe I can make it cheaper than buying any kit. If I'm right, which I hope, all I need are the backing plates, rotors, pads, calipers and brake lines. The ebrake in the drum might be transferable over to the new backing plate. I could redrill the rotors to 4 lug, which might do if funding doesn't go well.
right on.. just figured maybe you discorved something new with the eclipse rear hubs..
Dont know if this helps or if I told you already but I've confirmed the spines and outer diameter on the outer cup on the lancer are the same as on the 2g. In short 2g axles fit into lancer hub/spindles.
Update: Here are some new pics of some older stuff I put on.
Short Shifter with evo ball type knob. very comfortable.
Evo Gauge cluster
Custom grounding wire kit. Still working on it. Haven't decided if I will use one of those circle things that go on top of the battery. I've had problems on those before. I did this to help the headlights not flicker so much with my sound system.
Evo Gauge cluster
