Lancer OZ with Evo Exterior + 4g63T+RWD
#52
it must be the camera angle.. I have the whole front evo subframe from rack to control arms to the whiteline roll center kit installed.
Maybe its just the dummy tire that makes it look weird.
as for the axle, I was never able to test to see if it worked (hit anything) I tossed my stock lancer knuckles once I pulled them off.
From the old thread, where they guy tried to use the evo LCA's on his ralliart, it looked like it wouldn't work anyway.
Thanks again for all the positive feedback guys
#55
The front has the evo spindles which are already 5 lug and the rear end fitted with the outlander rear end will have 5 lug as well. Updated pics very soon guys.
I will say that the outlander rear did go in without to much trouble, the trunk floor needed to be slightly adjusted to allow for the bulge of the diff pumpkin. Hardest and longest part was drilling the hoes through the frame rails and all the metal, then sleeving the holes properly since I wanted to bolt the outlander rear end in vs. welding it all up.
#56
#58
You know, I was planning on just going FWD if I did an 4g63 swap, but if it wasn't too hard to have this done, I will reconsider and go awd. I know it ain't an evo and won't outhandle one, but with lighter weight, might outrun one.
