View Poll Results: Which rim size is the best?
17s
64
74.42%
18s
18
20.93%
19s
4.65%
Voters: 86. You may not vote on this poll
Which size rims for a LANCER ES?
Old Nov 9, 2003 | 03:40 PM
  #31
hbmike's Avatar
best tire size's are 205/40 or 205/45 for 17's
Old Nov 9, 2003 | 04:22 PM
  #32
pearlwhiteoz's Avatar
i second that!! 205/45ZR17... best size for 17s on lancers
Old Nov 10, 2003 | 08:02 AM
  #33
Powder's Avatar
I plan to get 16's on mine. I am willing to give up a little "looks" for a better ride and more protection for the rims. They are less expensive too (I am broke). ANything looks better than these 14" hubcaps. Hahahahaha
Old Nov 12, 2003 | 10:35 AM
  #34
CulebraLancer's Avatar
Im gonna go for 18s i want the nice look
Old Nov 14, 2003 | 10:07 PM
  #35
Rasputin's Avatar
Jesus.
I'll put it this way, 18s are asking for trouble.
I'm riding on my stock 14" steelies again for the winter. My Rota 17s are resting for now.
I hit one or two good old Jersey potholes and the rims are ok. My front right strut is pretty much ****ed, I can hear it when I roll over speed bumps.
My brakes have definately taken a hit. I need to get them swapped, all 4 wheels, as soon as possible. I don't brake hard, so I'd have to lean towards the weightier 17s giving the brakes more of a workout.
Lastly, I was close to having rubbing issues on my ES. 18s will probably toe the line quite dangerously and will look ridiculously large on a stock ES.
Just my advice, though.
Old Nov 16, 2003 | 08:48 PM
  #36
Well ive asked plenty of 18 owners about rubbing issues and theyve told me they have no problems at all.
Old Nov 18, 2003 | 10:57 AM
  #37
thacollection's Avatar
getting my 19s put on this week ladies, get ready for some eyegasms.....
Old Nov 30, 2003 | 11:38 PM
  #38
kensuke's Avatar
18s are not asking for trouble!
i have 18x8 and they work fine... i would recommend a +46mm (rear) offset if you're planning on going this big tho. go 18x7.5 as a general rule for 18s.. i only have x8 cause the 18s for this rim only have 8" wide available. just make sure u go with a 215/35/zr18 tire along with it. no bigger. don't go with a 40 series sidewall.. i already did that once and it rubbed. you won't be able to drop as far, but just get eibachs. they rock anyway, and you won't have to drop so far you'll kill ur struts
honestly.. people that hit potholes and bend rims didn't have their tire pressure up to par. with smaller tires, check it weekly at a minimum! the only way those should bend is if u run into something sideways or if your pressure is too low and the tire doesn't take the shock... or if u drive off a 20 foot cliff. but then you'll be worrying about more than rims
once again, 18s are fine... if you don't want the "hassle" of taking care of your investment, go with 17s. if you're uber lazy or hate rougher rides, invest in some 16s. anything smaller... just stay stock and don't waste your time with $50 rims that make you look like ur "ballin outta control!"
Old Dec 1, 2003 | 06:47 AM
  #39
Im not droping
Im not droping my car so i can i get a 40 sidewall and have no rub?
Old Dec 1, 2003 | 10:14 AM
  #40
kensuke's Avatar
honestly, i don't think it's a good idea. i had rub with my 225/40/zr18 setup, and i wouldn't be too sure that 215/40 would be any different. a lot of my rub was on the back over speed bumps, but i also had rub in my fender well when i made turns. if you're so worried about your rims that you can't go 35, do yourself a favor and don't get 18s.
it's not like 17s look bad, and you won't lose fuel economy either. in my opinion if you're going to go with 17s, go with a design that has the interior of the rim extending all the way out over the lip. example: enkei rs6 or rs8. nice 17s
Old Dec 23, 2003 | 12:33 AM
  #41
Drive02Lancer's Avatar
so wut is the widest tire we can go with a 17inch rim?
i do believe wider gives u much better traction lol
Old Dec 23, 2003 | 01:05 AM
  #42
Tanner65's Avatar
I agree with 17's, I'm not sure what the answer to your question ^ but someone reading this'll know since I just bumped it.
Old Dec 30, 2003 | 01:13 AM
  #43
toe point's Avatar
18's all the way, i had 17's on my ES and they looked way too small.. the 18's look great i have my coilovers all the way down and i hardly rub.. check it out at...
www.velvetseries.com and at .. www.lowlifevideo.com
Old Dec 30, 2003 | 01:23 AM
  #44
ghostrider's Avatar
I had 205/40/17s on my ES until winter rolled around. Then it was back to the stock steelies. For one, the stock tires are actually mud and snow rated, albeit prolly really ****ty. But it's gonna be a lot better handling than with the summer tires I have on my wheels.
I went with 205/40 series tires cuz it matches the radius of the stock 14s on the ES perfectly according to Whalen Tire. I don't want to bother with having my speedometer off.
I agree that 17s do look a little smallish, but it's more a design thing I think. When I get new wheels I'm going for something with the spokes actually extending all the way to the lip as opposed to having them stop short and tuck into the lip.
And I got to see Jason (thacollection) and his 19s, and they are TIGHT. For comparison, he's got about a 3 finger gap in his front wheel well. With my 17s on I have about a 1 finger gap and with steelies I have about 2 (with my car down about 2.75" up front).
Old Jan 24, 2004 | 11:26 AM
  #45
IILANCERII02's Avatar
I said and voted for 17's but i think on a ES u should stick with 16, because even if you dont think so now, u will probably end up lowering your car or get something for it to handle better, and the 16's would be really ideal for that.
Quick Reply: Which size rims for a LANCER ES?
