Dash Removal
Dash Removal
Does anyone know how to remove the dashboard. I just got a new guage indiglo reverse and need to intall it. Forum search just returned a bunch of non related info and I havent seen the sticky in how to's.
It's a real ***** getting the cluster out, so be careful, or you might scratch up the dash. Also, be wary of the clear plastic covering the guages. That thing could get scratched by a stiff breeze.
2 screws hold on the black cover, 2 more hold the cluster in place. They are copper colored and you should seet them once you remove the surround. USE A MAGNETIC SCREWDRIVER! If you drop these screws, you're in trouble.
Re: help!
Originally posted by BrettWiebke
Ive removed the dash to the firewall, so if you have any questions, pm me.
for the airbag don't worry, first disconnect the battery and right under glove box you will fine the airbag connector just unplug it
also the airbag is attached to the top part
it easer to remove the entire dash than the top part
