Aftermarket general maintainence parts?
I thought I was the only one with mucho miles on their Lancer.....I have 80k miles.
My question is, where do we go for normal maintenance parts (other than dealerships)? I know when I had to replace my brake pads a while back, I had to go to the dealer . A couple of months later they hit the aftermarket shelf. Need to replace fuel filter, should do timing belt (won't do that without a manual to refer to though), and any other normal maintenance items other than oil and oil filter.
Thanks for any assistance.
Todd
Todd
i dunno bout fuel filter since es/ls/oz don't have one, but everything else i've found at the auto store. pcv valves, oil filters, air filters, misc hoses, brakes, thermostats, etc all have aftermarket counterparts.
never really checked for belts and water pump at an auto store. i bought them at mitsubishiparts.com and did the timing belts, other belts, and water pump under 8 hours by myself. got a service manual on CD off of ebay for reference. you're gonna have to disconnect power steering so make sure you have fluid for it. don't forget to fill the reservoir back and it's gonna make a loud metal clicking noise that sounds like the engine broke, but after a while of idling while maintaining fluid level in the power steering reservoir, it'll go away.
some say sluggishness is because of either fuel pressure at the rail or the itty bitty size of bore of our fuel rail, or both. i agree to an extent. i also personally think it's because of a our stock timing maps. from 3000-4500rpm, it drops in timing from 15 degrees to 10 degrees and back up again.
bboy_RES
For Sale - Cars For Sale
Jan 9, 2012 03:43 PM
