Snowy weather and tire pressure question?
I know a higher-than-recommended tire pressure in the dry makes for much nicer traction and a lower-than-recommended tire pressure in deep mud or dirt makes for better traction, but what about in the snow? Is there a general rule for snowy driving that makes for best stop-and/go traction to keep me from plowing into someone?
-N
-N
Traction in winter depends a bit more on compound, design, and tread depth. You want a narrower path for snow, ice, or rain. Reducing the pressure will flatten the tire out and create a wider path making it a bit harder to tread debris. I would stick to the manufacture recommended pressures.
So then, if anything, higher pressures would help then? Lowering them to 35psi all around seemed to help me out last night from 40/35psi. I was considering going down a little more as well, bringing the rears down to 30 perhaps. That's still all above the manufacturer recommended numbers I think anyway.
Anyway, if there are no general relations between winter and air pressure, I'll just keep adjusting and seeing what works.
-N
-N
ericdecker
Nov 3, 2002 11:46 AM
