Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
how does strut bar work?
Old Feb 2, 2005, 09:02 PM
  #31
skylancer's Avatar
Originally Posted by Shingen
Those look great what are the prices?
Fox
I don't remember exactly...but I know the cusco & the carbing cost around $200 or more ...
spr is around $150 or more...
alutec & summit is around 100 or so...
that's the price I got about 7 or 8 months ago....so need to check...& I don't even remember where I got the price from...
Old Feb 2, 2005, 10:02 PM
  #32
GreenPsycho's Avatar
i'm sure we've seen these pics from rrm's site.
crappy:
good:
scruffy guy and pack of smokes not included
Old Feb 3, 2005, 08:47 AM
  #33
ItsTheDriver13's Avatar
Location: Danville, CA (it really is all about nor cal)
i have the pdxralliart deisgn bars. they are awesome!
Old Feb 3, 2005, 10:41 AM
  #34
bbvc's Avatar
I have alutec for the front & summit for the rear in my mirage now, I also have the summit trunk bar too but I haven't put them on
*** I used to have the cheap one on but it crack on the side for about 9 months so I replaced with these
here is the pic of them
here is the pic of the engine bay will take better pic later
Old Feb 3, 2005, 10:50 AM
  #35
Centrylancer's Avatar
but the greddy evo is
go with PDX strut bars, they are a great product and your supporting one of the guys here that crafts it for us!
support the folks that make em for you!!!
the link for the PDX bars is in my sig right here
Old Feb 3, 2005, 08:24 PM
  #36
Shingen's Avatar
I totally agree. I can't wait to get my rear strut bar and my tie bar from him.
Fox
Old Feb 5, 2005, 01:24 PM
  #37
Moderator
Bomb Squad Unit #02
urbanknight's Avatar
How does a strut bar work?
Imagine the forces that are exerted on tires as a car corners. If you are turning to the left, the car is leaning to the right (opposing force + right) which would make the outside tire grip and cause the outside strut to bend and lean in that direction. The inside strut, however, isn't under much of a load because its tire is coming off the ground (in some cases literally) and isn't gripping the ground, so it doesn't lean. Because of this, the distance between the tops of the struts increase because one is leaning away from the other.
OK that's great, but where does the strut bar come in?
Well, the strut bar is solid and holds pretty much the same length (tensile strength I believe) and since it attaches to the tops of the struts (the parts that are trying to lean away from each other) it keeps them from leaning.
So how does all that crap affect the traction?
By keeping the outside strut from leaning, it keeps the tire from leaning onto its side. In essence, it maintains the car's original camber (alignment), which allows it to keep more of the tread of the tire on the ground, thus giving it the best grip.
This also explains my position that the sway bar is more important than the strut bar. But they both help to maintain the best tire traction possible (that and heavier shocks and springs)
Any questions?
edit: Oh and the reason you missed the other posts on this is because you had the word "help" in your search. I don't think any of our previous threads had the word help in it. That and they are in the suspension forum, where I just moved this one to.
Old Feb 5, 2005, 01:27 PM
  #38
wingnut17's Avatar
Originally Posted by arnold16890
don't buy that one, go to either rrm, or rdd (aka, pdx)
Old Feb 5, 2005, 06:19 PM
  #39
arnold16890's Avatar
thanks for the awesome pics, greenpsycho. Thpse pics clearly showed us how useless the cheapo strut bars are.
And thanks urbanknight on the detailed info.... i guess i'll save up and maybe get one of those "non-brand name" ones that work still fine
Old Feb 5, 2005, 06:26 PM
  #40
Evodreamer28's Avatar
I got a strut brace from freedom designs, the so called cheaply made design but ya know what I will wip through corners at high speeds with no problem, get no rubbing on my intake manifold, I guess its just personal preference they all do the same and just to let you know those solid ones do flex aka twist when turning so they end up doing the same thing pretty much anyways
Old Feb 5, 2005, 06:42 PM
  #41
Moderator
Bomb Squad Unit #02
Yeah, the one in the pic where Rob is standing on it and it's bending... that'sa Freedom Design one. But you're right, since they work on tension, how much it bends under a verticle load isn't as important as some may think. However, my Freedom design one made popping sounds and pulled out of the threads when I went around a hard corner. But that's an autocross corner that's really sharp, taken sideways, and on really sticky tires. So if you're just cruising or driving at say 90%, you won't notice it.
Old Feb 5, 2005, 06:43 PM
  #42
Yeah I beat my car but not that much corners here in pa are sharp but dam they arent that bad
Old Feb 13, 2005, 04:29 PM
  #43
how much are they?
Old Feb 13, 2005, 04:36 PM
  #44
ambystom01's Avatar
Depends on which one you get, just look around.
Sighs
Jun 28, 2017 08:29 AM
fabilloPR
Mitsubishi TC-SST Discussion
May 22, 2016 03:26 PM
sleepy_rps13
22
Jan 30, 2015 10:01 AM
03silverevo
Aug 22, 2007 03:43 PM
rbbcustom
Aug 28, 2003 07:14 PM
Quick Reply: how does strut bar work?
