wilwood brakes
1) what does high hp have to do with braking? not a thing.
2) rear discs and mainly a show mod, for our weight drums are just fine unless you do a lot of road racing b/c discs wont fade as fast as drums and they cool faster.
3)Big brake kit will give you that touchy feel b/c it is add more pistons, but your braking distance will probably not decrease as much as you think it will. Making these mainly a show mod unless again u do a lot of road racing.
If this is wrong someone fill free to input their thoughts.
check here for the track tested willwoods, he came from slotted dimpled & cryoed rotors
http://206.72.71.199/sclc/forums/vie...hp?p=8446#8446
this probably goes without saying but the wilwood kit wont fit the ES will it.....the ES has a 4 x 100 bolt pattern which I know is drastically different from the OZ or LS pattern. Is the wilwood kit only available for the OZ model or is it like the RRM slotted rotors and they just have to send you a differnet bolt pattern rotor?
bakuro117
For Sale - Wheels / Tires / Suspension / Brakes
May 8, 2017 02:25 PM
george3
15
Aug 5, 2009 08:37 PM
chet
16
Oct 16, 2007 02:28 PM
Paul Nelson
21
May 21, 2007 05:07 PM
