squeaky rear suspension
whats up people, i have had my progrees springs installed on my car for about two and half years now. just recently my rear suspension is starting to squeak pretty badly. don't know what it could be really, im gonna take her to the mechanic on tues. any suggestions on what may have caused this or what it could be. thank you
also, just wondering if it could be anything else. i think its weird how both left and right sides of the rear suspension just started squeaking around the same time. could it be anything else? thanks again.
I have had mine for probably about 1 1/2 years and I just started to notice some sqeaking as well, but mine I hear more in the front. I get the noise whenever I am going up a curb in to a driveway or somthing like that.
You may need to just tighen the top strut nut. One way to check that is the jack up that wheel and then grap the side of the tire, fingers in the tread and pull and push the wheel back and forth as if you were checking for bad bearings. If you hear it rattling or clanking, then the strut nut is lose and needs to be tightened. Again, it may be getting loose because your struts are going, but give this idea a try.
Sounds like the struts. Mine left rear went bad (stock springs) after 20k, and my right rear is now squeaking. I'm over 30k now, so no more warranty. Good thing I'm getting Tein BASICS by the end of the summer.
A good way to check is open the rear door, stand on the bottom of the door frame, and rock the car. If you hear a squeak, then it's most likely blown struts.
ok i got out of work and got on the rear driver side door ledge and bounced up and down, suprisingly i heard not one squeak. now, when i got home after driving i did the same thing and it squeaks. is that a sign of blown struts. i just think it awkward (sp) that it didnt make a single squeak when i got out of work.
I have the same stupid squeaking. I got under my car while someone bounced up and down in the rear seat. MY squeaking came from the bushings on the lower rear sway bar. (I have the Eibach Pro-Kit) I took it over to the dealership and they said they would replace them for free and check to see if I had any other suspension problems. I told them my front bushings were squeaky too. They also will replace those under my warranty. I just have to find the time to get over to the dealership. The service manager said over half of the people who brought their lancers in have had the squeaking bushing problem---all have been replaced under warranty. He told me they might do a recall.
so what's up with that recall? i have the same problem in my lancer.. the back squaks like hell.. although im at 40,000 miles now so i don't think warranty will fall in place.
