Attention 02-03 OZ Rally Owners!
If anyone with an 02-03 Lancer OZ Rally is looking for a HOT set of OZ rims in our exact size, check out this link.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
I really wanted to get these but they popped up on ebay exactly 24 hours AFTER i ordered my Superleggeras. What an amazing deal.
won't fit the OZ, if you look at the bottom of the page, at the Question & Answer section, you'll see this:
Q: what is the width and offset? thanks mark Jun-22-05
A: sorry about that. Heres some more info. Bolt Pattern: 4x100 Offset Range: 38 to 45 Wheel Size Range: 14x6.0 to 18x7.5 OEM Tire Size (Front): 185/65-14 (185x596 mm) Max Tire Dimensions: 215x611.0
So those wheels are more for us, the ES guys
Bomb Squad Unit #02
I worry about the 38mm offset though. When you get to a 7" width, you want to be more around a 42mm ofset. Yes, the stock rims have 38mm but they are 6" wide. The wider you go on a FWD car, the more offset you need to keep from rubbing the fender. 38 might still work, but only with a narrow tire (like 205) just a heads up if anyone on here bought them.
And yes, he corrected his answer as it's a dual lug pattern, fitting both the OZ and ES.
Ozturbo
Lancer Tranny/Drivetrain Tech
11
Nov 7, 2006 02:31 PM
