tire noises
tire noises
hey everyone! so today i rotated my tires...and i was wondering, do i need to have them rebalanced? cuz i'm hearing a wierd "hmmmmm" sound when i drive and i can't see it while i'm driving but i bet they are wobbling cuz they're not balanced from before seeing has how they've been rotated and all? what do you guys think? thanks a bunch!
-+> Ozzie
-+> Ozzie
![Moderator](https://www.evolutionm.net/forums/images/titles/mod.gif)
Bomb Squad Unit #02
Did you only rotate them front and back, or did you switch sides also? If you switched sides, try puting them back on the original sides. If not, the noise could just be because of the new tread feel (your front tires will now have a flatter stance while the rears are now slightly roundes), in which case the noise should go away soon, assuming you rotate your tires at least every 7,000.
If the noise doesn't go away soon, you could get them rebalanced. I think some places recommend that anyway, although I've never had to with mine.
barneyb
11
Oct 7, 2014 06:55 AM
