Are these Low-Profile tires?
Originally Posted by sykou
I want a tire with a sidewall like this
in a 195/60-15 size but all i could find at the tire shop were tires that looked like the first pic....even with the stock tire size. Oh BTW the tires i was looking at were coopers....dunno if it makes a difference from brand to brand or what.. thanks for everyones help
I've narrowed down my tire choices to these two tires.
- Yokohama ES100 $296 from TireRack
- Kumho KH11 $184 from TireRack
But the thing is i don't want to use low pros on my stock OZ rims(15"). I know i could use one but i don't like the look of a low-pro on a small rim.
If anyone knows if these tires are lo-pros or not, it would help me a lot. Thanks.
To whomever wanted the higher profile tires, I made a mistake once before and put 205/60/15 tires on. I now have 205/55/15 but I just wanted to let you know the 205/60's will fit but they rub a bit on full lock turns. The thing with that size tire is that your speedo will run slower than your actual speed. I have 2 tickets to show for that.
The 205/55/15's I have do not have as tall a side wall but still give some width. They are only supposed to be off by less than 1mph at 70 on the speedo. (69.2)
WADAD
WADAD
Bomb Squad Unit #02
If you order the same size as stock (195/60/15), you won't have low profile. The 205/55/15 I have on mine look a tad more low profile than stock, but still not much. But as said above, it's more of a slang term, and most people will consider anything less than 50 aspect ratio to be "low profile". Hope that helps.
Oh yeah, and you won't have much of a problem mismatching the fronts and rears. The road feel might be a tad uncomfortable, but it won't be dangerous or detrimental. I personally prefer the same tires, but when money is tight, I only replace as needed.
Jonno99
19
Jan 23, 2016 09:17 PM
Golovko
11
Nov 22, 2006 01:04 AM
sykou
Nov 15, 2005 11:57 PM
Trbo Dad
70
Nov 2, 2005 08:11 PM
createacat1
Sep 25, 2003 10:23 AM
