Sway Bars( Front + Rear)
I have been researching for a long time now, and even though the RMR front sturt bar is way more expensive than the RRM sturt bar, it looks stronger, and more fit for the job. If anyone has either of these strut bars i would appreciate your input. Also, are there any rear sway tower bars or are anti-sway bars only needed?Thanks.
to start...this is niether site feedback or a suggestion, so just pay attention when you are posting a new thread.
I have the RMR Strut bar, and i love it. I personally think that it is a shade better than the RRM singel tube strut bar, I jsut dont trust all the pressure on one bolt. Im not sure about thier K-Bar, but i havent heard anyhting bad about either of them.
Procarparts.com has reat upper strut bars, but they are not as benifical, imo, as a lower rear sway bar.
just for your info
it is my understanding that strut bars reduce body roll. this is important for weight transfer, and helps the car feel more solid around corners.
sway bars are more functional. they actually torque down one side of the car to maximize tire contact patch, which improves grip during cornering.
someone can correct me, but it seems that a strut bar improves handling slightly, but what it really does is make you more confident by reducing roll. a sway bar is goign to actually improve your handling more by increasing contact patch.
http://www.procarparts.com/store/dis...02-03%20LANCER
they have both rear and front strut bar. obviously the stiffer a strut bar is, the more rigid and less body roll your car will have. but i don't think you'd be disappointed with any of them, as the difference between them is probably minimal.
i have the sway bar, and it is amazing. definitely worth it. i plan on replacing the springs/shocks eventually, and once that is done if i feel that a strut bar can still improve handling, i'll add it last.
i got the rear strut tower bar from procarparts.com and i noticed a small but good difference in handling. feels much tighter in high speed turns (60mph and up). i definitely plan on getting a front strut tower bar from either RRM (k-bar) or from EG if they start selling the one they have in development. then i'll go with a rear sway bar, and finally adjustable struts/shocks, that is... if i don't blow the stock ones in the mean time.
i agree with crzylizard about the single RRM strut bar..... just don't trust one bolt no matter what anyone says, plus it doesn't look that good.
first of all a strut bar and sway bar are totaly difrent things.
a strut bar will not reduce body roll!!(it stiffens the frame at the strut mounts) the sway bar on the other hand will reduce body roll by conecting the wheels. when one strut is compresed by turning the other side extends pushing down. the sway bar will
twist under these loads thereby reducing the independint movement of the struts. a larger bar will place more weight on one tire (reducing overall grip) often all of the weight when the inside tire lifts off the ground. that is why a larger bar in the rear will make the car oversteer. (biger bar reduces grip) I hope that clears things up.
EDIT: Is this pretty much what you were trying to say about sway bars?
You will never drive beyond the strength of single strutbar like RRM's. Even wider street tires could not exert enough force to bend that bar on single bolts. If you run racing slicks then.....
that's pretty much the thing on strut bars. i've got the rrm single tube - reason being: why pay more for stuff you dont need? this single bar will be more than enough.
sway bar: the rear sway bar offered from rrm/progress is probably the most noticable modification to your suspension(driving wise) you'll feel an immediate difference in body roll..it'dd feel 50% reduced..maybe more. but if you get one of these, be sure you get their sway bar perches too. the stock perches are ****..mine snapped in half on both sides.
both are well worth the money and rrm has done a great job engineering them
Bomb Squad Unit #02
if youre really in a hurry to get bars id go with rmr just b/c they look beefier than the rrm bars. if you want, id just wait to get them.. i am currently sponsored by freedom design... they are a division of racing dynamics. they are currently waiting for their bars to come in. mine should be here by carlisle. they got some really nice stuff. i know this sounds like a plug but these guys are sponsoring me. if anyone got any questions pm me and ill tell ya whatever you need to know
these guys have been in business for over 30 years and they mostly deal w/ porsche, bmw and all the high end cars but they love our lancers.
I can't wait for my bars to come in, it'll be on rails
they are also working on various things, i.e. CAI, the list just goes on.......
