lug nut torque spec issues
i have the gorilla locking lug nuts on my car and the damned things keep loosening up. i had one wheel's nuts re-tightened when i got an alignment last sunday, and today i just torqued all of them down to 110 ft/lbs with a torque wrench. i did 100 or so before with an impact wrench, but at least two nuts on each wheel (aside from that wheel i had re-torqued) were FINGER TIGHT today.
has anyone else had issues like this? will these stay solid this time? usually i end up over-torqing the lug nuts because i do it at work with our crazy powerful impact wrench. what do you guys set yours to when it comes to torque?
haha, that is what i used to do as well... trouble is that when i bought the car the dealership (which was a dealership, too!) didn't give me a damn lug wrench and i didn't want to drive to manchester (NH) to get it.
i may use threadlocker if they loosen up again. after using my torque wrench i hit them with the air gun at work in the morning. i haven't had any issues.
i got my power steering back in order today and i finally can DRIVE the car with the new coilovers. it handles excellent! hopefully my sway bar perches from RRM come monday and i can get my progress bar back on.
thanks for the responses, guys.
torque is 80lbs on a lancer 110 are you ****ting me you just jacked you studs then spun those babys in the hub 110 on a 80lb car you probally will warp your rotors and even more nice guys nice or it can be your wheel i.e the lug holes are flared out from over torquing them and it spins the lugs lose
Yes.. overtightening the lugs can warp the rotors. I've had that before when Discount Tire used their impact gun on my old Talon/Eclipse, and my parents have had that problem before at the Chevy dealership. I use a torque wrench and tighten them carefully in a star pattern between 80lb and 90lb.
I had gorilla's before I went Muteki, and they stayed on fine, tightened with just a torque wrench to 90ft/lbs. I have a stupid question, considering your occupation, but I have to ask. You are tightening them in a kind of X pattern, right? You aren't just tightening in a circle, are you? I just had to bring that up, because I know that can cause uneven tightness in the lugs, causing some to loosen. Also, are you sure that the lugs have the correct seating for your rims? I think I read somewhere on here that conical lugs didn't match with where the lugs seat in the OZ rims. I don't know if this is true, because I don't have an OZ Edition, but it's something else to check. I think there was a vendor on here arguing with someone who wanted to buy lugs from him, which he said wouldn't work for that reason. Again, I could be wrong since I drive ES, but check it out.
yeah, star and then circle. the issue could be with the specific lugs on the rims. that's something worth checking out, i'd never even heard of that.
november to january and i have not warped the rotors at all. granted it may take more time, but i've seen lugs torqued way over spec on literally hundreds of cars and none of them have had issues with rotors. i am sure that this is a problem that can (and does) happen, but i have not expierienced it myself. i will keep this in mind... but when it comes to superalf574's first post... i can't really decipher what he was trying to say. i am sure that rotors would warp with EXCESSIVE amounts of torque... like in excess of 200. i highly doubt that 20-30 pounds will totally screw the rotors up. it's not like we're tightening something that should be tightended in inch-pounds.
undercoverpope
20
Jul 20, 2011 10:54 AM
vtluu
Jul 24, 2005 08:33 PM
nubby
Apr 24, 2005 03:46 PM
