goodyear 205/65r/15
goodyear 205/65r/15
i found a set for 50 dollars for all four! does anybody have tires with a 65. imo it might look to big, but i cant beat the price.
4 goodyear assurance triple tread with 75% tread remaining.
Mileage Warranty:
80,000 miles
Specifications:
Treadwear: 740
Traction: A
Temperature: B
Speed Rating: HR
$100
Mileage Warranty:
80,000 miles
Specifications:
Treadwear: 740
Traction: A
Temperature: B
Speed Rating: HR
$100
The "205" tells the width of the tire in mm
The "50" tells the profile or height of the tire from the rim in mm
Read up on it here:
http://www.goodyeartires.com/kyt/readingATire/
http://www.yokohamatire.com/utreading.asp (click on the various links)
You should be able to on 205/65r/15 with no problems
Read up on it here:
Last edited by Blacksheepdj; Dec 22, 2006 at 06:46 AM. Reason: Cleanup from deleted post
Mileage Warranty:
80,000 miles
Specifications:
Treadwear: 740
Traction: A
Temperature: B
Speed Rating: HR
$100
Mileage Warranty:
80,000 miles
Specifications:
Treadwear: 740
Traction: A
Temperature: B
Speed Rating: HR
$100
185/65-14 4.7" sidewall 11.7" radius 73.7" circumference 859 revs/mile
205/65-15 5.2" sidewall 12.7" radius 80.1" circumference 791 revs/mile 8.6% difference
If your speedometer says your are doing 60mph, you will be doing 65.2mph
Dont do it!!! When i bought my 04 ES the previous owner put 15 inch rims on it. He also wasnt thinking when he put on Goodyear 195/65R15 tires. After i bought the car, i would back out of my driveway i wouldnt be able to turn the wheel all the way without my front tires scraping against the wheel base. Also when i would have 3 people in my back seat i would take turns and hit bumps and the rear tires would rub. I just recently got new Hankook 195/55R15 and no longer get the scraping when reversing and to make sure it wasnt my shocks being warn in the back i got 3 of my FATEST friends a put them in the back seat and the rubbing stopped on turns and bumps So getting the 205/65R15 would be a bad idea!!!
stock size on my 02 OZ is also 195/60R15. i have these on a set of TEIN basics dropped to where there is ALMOST two finger's worth of gap all around and i experience no rubbing... if this helps at all.
Bergen Automotive
45
Jul 3, 2010 11:53 AM
doghead
Sep 26, 2009 05:34 PM
