Pro-kit or Sportline springs?
It depends on how low you want to go. The Pro-Kits have a slightly smaller drop compared to the Sportlines. I think you'll be happy with the Pro-Kits unless you like the really low drop look.
No matter which spring you buy you'll need a new set of shocks. The stock shocks won't be able to handle the higher spring rates, and you'll be bouncing around for a few months till they blow and you end up having to get a set anyhow. The labor time will be the same since you have to remove the the shock to get the spring off anyhow.
Mark
Mark
I've never heard of sensa tracs. Decent aftermarket performance shock companies would be Koni, Tokico, KYB. I'm not sure which companies have shocks available for the US Lancer yet. Eibach also have a Pro-Kit shock line which may go nicely with a set of their Pro-Kit springs.
Technically this setup isn't perfect because the aftermarket shocks aren't valved specifically for the spring rates, but unless your a heavily experienced racer, it'll make no difference. Koni's have a lifetime warranty and are easily rebuildable or expandable into a better shock, so if you plan on track events and autoxing they're a great buy. Otherwise a set of KYB AGX will be the best buy from a price / performance standpoint.
Mark
Mark
I understand the Pro kit Eibachs would be better with stock shocks. The idea is to keep the shocks from hitting the bump stops all the time. That is how you kill shock and have that f'ed up ricer ride.:soapbox:
eibach
If you go with the sportlines and you have the OZ I suspect yu will be dragging on curbs all the time. Thats a really low spring. I have the pro-kit on my talon and it is great. If I decide on new springs for the Lancer, it will getthe pro-kit. As far as shocks, the stock ones will be gone is way less than a year with lowering springs. It's a fact. It is not even worth it to take apart the suspension twice. Just wait and do it right the first time. The AGX's are a nice match to the prokit (at least on the dsm).
With pretty much any of the current spring sets out right now, you'll want to change the stock struts. They just can't handle the spring rate of aftermarket springs. They won't be able to fully dampen hits your car takes and you're going to bounce like some sort of crazy kangaroo. The Pro-Kit is least likely to cause initial problems with lowering but it'll still be tearing up your struts. The Sportline and it's nasty drop will definitely require new struts, same goes with those Arospeed springs... In my opinion the Sportlines and the Arospeed drops are just to low to be practical.
Any Idea??
Any idea where I can purchase reasonably priced aftermarket shocks?? I recently bought Eibach's Pro Kit and I dont want to mess anything up. Any info would be appreciated.
