Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
This is why you need to inspect your end link bushings!
Old Aug 19, 2007, 10:47 AM
SLVROZ_03's Avatar
In horrible condition...
In "ok" condition...
Side-by-comparison...
Used my new $20 (AutoZone) Energy Suspension end link kit
P/N : 98120R
...and they are awesome! Much more solid in the turns; one of the best/cheap improvements. Others have installed the new kit as-is, but the center sleeve between bushings is just too long. I used the stock sleeve instead since it's in prefect condition and allowed a much simplier install than forcing it together.
And since I don't care to make another thread, I'll just add this here. Some know how the Evo's front stock suspension works great on our Lancers, so I picked up a cheap used set. If you do, you NEED to get the Evo camber adjustment bolts (OEM [$11] or aftermarket)! Even after only a couple weeks I noticed the inner passenger-side tire wearing more than it should. Just a word of advice...
Old Aug 19, 2007, 10:59 AM
Noe18's Avatar
is it a straight bolt on??
Old Aug 19, 2007, 11:10 AM
SLVROZ_03's Avatar
Yep, honestly w/o the wheels on it's easier than an oil change! But just like I said above, I used the factory sleeve instead of the ES one cuz it's much shorter and allows for a much easier install. Yes, completely bolt-on; about a 10 minute job with the wheels off.
Now I have to get a set for the rears, cuz I have one that looks exactly like the bad one pictured. Odd, both "bad" ones are on the driver-side...
Old Aug 19, 2007, 01:52 PM
Former Vendor
crypto's Avatar
yeh i got some of these, i have yet to install them though
Old Aug 19, 2007, 04:38 PM
SLVROZ_03's Avatar
^It's like a 20 min job! You'll like...
Old Aug 19, 2007, 07:08 PM
Former Vendor
crypto's Avatar
yeh i know, it looks simple. my bushings are pretty trashed too, also the rear ones. i was planning on test fitting them to see if the rear are the same. anyone else already try this? save me some work.
Old Aug 19, 2007, 07:37 PM
JohnnyBoy427's Avatar
You should be able to inspect them with just a look under there correct?
Old Aug 19, 2007, 07:43 PM
03_Lancer_ES's Avatar
Yeah, you'll see them just from taking off the tires. Mine were broken, apparently the stock ones are very prone to rust. If they're still somewhat intact, you can literally just unbolt them and put on the new ones, if not, you'll have to cut them off like I did.
https://www.evolutionm.net/forums/sh...d.php?t=284624
Check that thread for my story and pictures...
Old Aug 19, 2007, 07:50 PM
OK wow. so it isnt supposed to be away from that arm like that?
Old Aug 19, 2007, 09:58 PM
KillahB's Avatar
LOL I know the feeling ....
My bushings
Old Aug 19, 2007, 11:12 PM
eyekyu's Avatar
where do i find these now i wanna check mine
Old Aug 20, 2007, 08:11 AM
SLVROZ_03's Avatar
End links are what connect your sway bar to the control arm...both front and rear.
The rears will only use a half set of this kit, cuz...well, if you look you'll see why.
Old Aug 20, 2007, 08:21 AM
Nope, they're supposed to be bolted to the arm...
Old Aug 20, 2007, 11:16 AM
I guess we learn something new every day. Glad I joined this site.
EVOM FTMFW!!!!!
Old Aug 20, 2007, 04:05 PM
see something wrong here?
so I checked mine today and sure enough. One is busted. Im guessing I can still drive it like that though cant i? and it looks like that bottom part is broken off. the new part is the whole assembly right? I couldnt find the rear ones. The ESs dont have those in the back correct?
Does anyone know what that clip is in the second pic that im pointing at? its on the back of the rotor guard.
Attached Thumbnails This is why you need to inspect your end link bushings!-0820071730.jpg   This is why you need to inspect your end link bushings!-0820071719.jpg
Quick Reply: This is why you need to inspect your end link bushings!
