Other slotted brake options?
I just got my new axxis pads today and I need to order new rotors. I am looking at the street series slotted rotors from RRM. I haven't heard anything but good things about them. I was wondering if there are any good ones that measure up to the RRM ones for cheaper?
RRM street series are just slotted rotors. RRMrace series are exactly the same, just powdercoated on non-contact surfaces.
Tire Rack has Brembo slotted rotors for around $155. www.tirerack.com
Price own'd! http://cgi.ebay.com/ebaymotors/Lance...QQcmdZViewItem
They do say at no additional charge they can do just drilled, just slotted, whatever.
Good luck!
EDIT...sorry non-ES only. ARRRGGGHHH
Good luck!
Good luck!
Good luck!
I just went ahead and ordered the street series slotted rotors from RRM. I'm sure I will be satisfied. Thanks for trying everyone!
I have power slot rotors and axxis ultimates... I have some goodridge stainless brake lines just sitting in my trunk right now. Having these breaks on just makes what I was running stock seem like a joke.
I have the Brembo Sport slotted brake rotor that I ordered from Tirerack guess it doesn't help the es guys, but here's the link:
http://www.tirerack.com/brakes/brake...=& perfCode=S
I also have the PORTERFIELD R4S BRAKE PADS from TopBrakes. Here's that link:
http://www.topbrakes.com/order.cfm?p...TOKEN=74920657
The combination is great. Very strong stopping power... you just have to be careful when driving another car because their brakes are NOT going to stop you as fast as these will unless of course you are driving an evo...
I heard people talking about breaking in the brake pads? What does that involve? Also any tips for different compounds and lubricants and whatnot that would help my install? I think there is stuff that you put on the back of the pad but I'm not sure. Also do I need to re-use those metal backing plates from the stock pads?
Re-use those shims and replace any missing or worn brake pad brackets (the little metal clip things). Break-in procedure is on the brake pad box; but basically you find yourself a little road that doesn't get traveled much. Do this 7-10 times. Accelerate to about 30ish and brake with a medium firmness until you're about 10 mph. Then speed back up and redo 7-10 times... You will smell the brakes breaking in, but you'll be fine.
I got my rotors and pads put on and WOW. HUGE difference. I had some fun breaking them in. As a matter of fact I had so much fun they were smoking a LOT! Maybe I got some oil on the rotors or something. Now I have a question. Do the Street Series rotors come powdercoated too? Thats how mine came.
anbuzero
Mar 22, 2010 08:39 AM
HaVoC RR
10
Jun 26, 2007 11:34 AM
Kurt
15
Oct 1, 2004 08:11 AM
