brembo brakes
ok thanks...nt spending money on them..oready hv them frm my previous ride which was a total wreck..hahahah,guess ive got to sell tham brembo brakes..
The best answer would be:
No, they won't bolt up, even with minor modification. But if you have the ability to make custom brackets and get custom brake hoses, it'll probably work.
The brake calipers for the X are the same as the calipers on the VIII/IX. If the spindles on a Lancer and X are the same, then there will be a factory brackets to use Evo brake calipers on a Lancer.
Dealers should have parts lists for the X by now.
thanks mate..thats a very encouraging piece of info..im gonna check it out tomorow wit the garage..cheers
The Brembos are close to the GTS spindle, but you can't get both bolts in. The rears are pretty far off.
The gts brakes are more than good enough. With a great amount of power comes the need for greater stopping power and the lancer isn't as fast to require even bigger brakes.
tom@kartboy
43
Jan 5, 2017 04:57 PM
